Multisim and Ultiboard
Multisim database crashing program
Every time  I open the database manager in Multisim 12.0 and click on the component tab the program crashes. If I click on the RLC components tab it seems to work fine. Anyone else have this happen? Is there a quick fix? Thanks   Kim
Message 1 of 8
(7,429 Views)
Hi Kim,
Thank you for your post. Just a few questions before we can further diagnose the issue. Could you please tell us your operation system? Is it Win7 32-bit? Or, are you running your Multisim on a virtual machine? Have you installed any updated patches? When did this problem happen?
So far by the information given, it might be due to the path of a database(say, corporate database) cannot be found or the configuration file is crashed in your Multisim 12.
Chen_T
Message 2 of 8
(7,406 Views)
HI Chen. I am using Windows 7. 64 bit. on stand alone system but networked.  My corporate database is stored on the server so that everyone can access it. I have not installed any updates or patches. I don't know when this started because most of the rest of the program seems to be working fine. I was trying to clean up some of the components that have been created with unusual names, duplicates with different names etc when I discovered that I can't access them. I can access them to place them in the circuit but not when I go to the database manager and try to remove or rename them.
thanks
Kim
Message 3 of 8
(7,402 Views)
Hi Kim,
Please try these steps:
1. from the main menu select Options »Global Options »Paths, find out where you corporate database file is located and then navigate to that path using the Windows Explorer
2.  Close Multisim and Ultiboard down
3. Move your existing corporate file to a different location and then replace it with the attached clean corporate database
4. Start up Multisim
5. Tools»database»Merge
6. Merge your corporate database with the clean database by select Tools»Datbase»Merge. The steps are similar to what is described in this knowledge base
http://digital.ni.com/public.nsf/allkb/0E79A33B64DBC6DB862579EB0050F6E8
Tien P.
Message 4 of 8
(7,396 Views)
Hi Kim,
It can be the corporate database problem. Do your colleagues in the same network also have this issue?
My concern is that it could be linked to the corporate database. That is the only shared database. I have attached a clean corporate database to this post. You can try to point your database towards this in Options >> Global Preferences. Apply the changes and close and re-open Multisim. Open Global Preferences again to check if the changes are applied. Try to access the Database Manager after this and see if it works. If it does, we know that something is wrong with the corporate database for sure.
Please let me know what happens.
Chen_T
Message 5 of 8
(7,392 Views)
Thanks Chen. That worked. Now what ? Can I merge my old one with your new one?
Kim
Message 6 of 8
(7,387 Views)
Hi Kim,
Yes, try to merge the old one into the new one. Just follow Tien's instructions described in the previous post.
Let's see what is gonna happen.
Chen_T
Message 7 of 8
(7,384 Views)
Accepted by topic author Kwood1158
Ok. It took a couple of tries but it worked. I must have tried to merge backwards or something because when I was done it only had an empty database with a file size of 1K. I did it again and it worked. I have all my files back in the correct places now and all my components work great. The merging process needs a littlle bit more explanation I think.
Thanks very much Chen and Tien for your help.
Kim
Message 8 of 8
(7,379 Views)
