Multisim and Ultiboard
Multisim database is not complete how do I update
Hi jkb007,
The MAX1709 model doesn't exist in our database now, which means you have to create your own. However, to create a new component you need its SPICE model which is not available right now. Maybe you can try to find something similar.
If you want to create your own component, you can follow this instruction:
https://decibel.ni.com/content/groups/circuit/blog/2011/04/06/component-creation-101
Derek Z.
Message 11 of 20
(11,673 Views)
The component CD4026B don't exist in database. Please help me...
Message 12 of 20
(11,179 Views)
IR 2103 can be created with the Component Wizard; the following link is a tutorial on how to create a component.
http://www.ni.com/white-paper/3173/en
When creating a component using the Component Wizard, you will require the spice model, which can usually be found on the manufacturer's website.
You can download the psice model from the following link; open the file IR2103.sub using a text editor and copy and paste the model into the Component Wizard in the corresponding step.
http://www.irf.com/product-info/models/sim/index.html
Sharanya R
Market Development Engineer
Message 13 of 20
(11,176 Views)
If a component is not in the database, you can create your own component using the Component Wizard if you have the spice model.  The following link is a tutorial on how to create a component;
The spice model can usually be found on the manufacturer's website, in this case I was unable to find the spice model on TI's website, if you can get the spice model from the manufacturer all you will need to do is copy and paste that into the component wizard.
Sharanya R
Message 14 of 20
(11,173 Views)
I have version 11 of the student edition and I can't seem to find DC/DC buck converter, the LM2574 chip, for a project I am building for my final. If anyone can provide me some assistance or direction on how to get it into my database, it would be greatly appreciated.
Message 15 of 20
(11,076 Views)
You can create this component using our Component Wizard.  The steps can be found in this tutorial
Creating a Custom Component in NI Multisim
The spice model is from Texas Instruments, you find the spice model on their website or you can ask them for it.
Hope this helps!
Sharanya R
Message 16 of 20
(11,069 Views)
I am missing the chip of DAC0808 and I am using multisim version 10.1.
Do I have to make by myself or can I download it from somewhere?
Message 17 of 20
(11,035 Views)
You will have to create it yourself using the Creating a Custom Component in Multisim tutorial.
The spice model can be found on the manufacturer's website (www.ti.com) and if it's not there you can ask the manufacturer for it.
Hope this helps!
Sharanya R
Message 18 of 20
(11,027 Views)
I cant find IC LM2577 boost regulator..anybody has this IC?
please help me..
Message 19 of 20
(10,224 Views)
comprei a versao estudante.
instalei.
nao tem DATABASE.
COMO PROCEDER PARA TER O DATABASE.
Message 20 of 20
(9,416 Views)
