Multisim and Ultiboard
Multisim giving incorrect measurements
Multisim is giving me different amperage readings for this circuit, depending on the placement of the resistors (the connections and circuit layout are the same).
What is going on here?
(2,289 Views)
Привет! Проверить соединение в обозначенном узле надо.
(2,251 Views)
Правильный ответ будет такой
(2,248 Views)
I am having a similar problem based solely on probe location:
So that's...not good...
(2,184 Views)
Completely untrustworthy software. Tried to report the bug to customer service and they wouldn't let me.
(2,180 Views)
I was able to report the bug; in so doing, I ended up noticing that if I save and load the circuit, the measurements work...which is to say:
turned into
which - eek...
(2,177 Views)
