Multisim and Ultiboard
Multisim glitches whilst modelling arc suppression coil
I have been trying to model the operation of an arc suppression coil in a high voltage three phase distribution system. I originally built the model on version 9 and found that instruments werent displaying correct values, and yes the circuitry and component values are correct! I since tried the same file on version 11 and the problem is even worse with very erratic instrument values. If anyone would like to have a look at my work and see what they can do then I can email the file to you.
Thanks in advance.
(3,740 Views)
I would like to look at what you have done if you post your file.
(3,670 Views)
