08-16-2011 11:07 PM
I have a large design. I need to update the FPGA symbols. There are 4 FPGA's and the symbols have 22 sections each. The 4 FPGA's are in duplicated subcircuits.
Changing the first on is fairly easy if I turn off re-wiring and delete all the old sections and then place new ones.
The problem is the sections placed in the other subcircuit instances all come in with different refdes. So I have to manually rename 3 x 22 sections. Each section takes about 5 minutes to rename.
Is there any option in MS to turn off whatever is being checked such as there is for UB where checking can be turned off or real tiem or on action end?
I've asked about this slow performance of MS here before and assume if there was such a feature I would have been told about it, but for the hours I'll spend doing this it's worth checking again.
MS should really have:
Those would be nice features to add.
Thanks.
11-22-2012 09:25 AM
I will pass this on to development as feedback for future releases.
