Multisim and Ultiboard
Multisim
I have been a long time user of Electronic Workbench (5.1) and have developed many circuit simulation files in teaching electrical engineering courses.. I can't use EWB any longer since it doesn't run on 64 bit machines. I have installed Multisim 12.0 but it doesn't recognize my EWB files. Any solution to this short of recreating these circuits in Multisim?
(5,479 Views)
Hi there,
Multisim 12.0 does not recognise EWB 5 files as a supported file type and as such you will not be able to load EWB 5 files directly into Multisim 12.0.
In order to view EWB 5 files in Multisim 12.0, you will first need to open them in an earlier version of Multisim. For example, open the EWB 5 file in Multisim 11.0 and save the .ewb file as a .ms11 file. You will then be able to open the .ms11 file inside Multisim 12.0 and save it as a .ms12 file.
Hope this helps!
Chen_T
(5,456 Views)
Hi Howard,
Please contact our support team if you cannot convert the files. If you are not able to reach our support team, send me a private message with your email address.  You can send a private message on this forum by clicking on the envelope icon at the top right then amd click on "Compose New Message" tab, enter Tien_P in the 'Sent to' field
Tien P.
(5,423 Views)
