03-22-2013 09:46 PM
I‘m tring to do the test with Multisim to find the relationship between PWM and the DC current. single phase , inverter with IGBT,
Please to see the attachment.
but it's wrong,how to deal with?
03-28-2013 03:42 PM
Seems to be a few things. You always need ground for your simulation to work, and a load coming from the source (as it is a rather high voltage source). I adjusted a few parameters under interactive simulation settings such a the precision of your circuit's tolerance (you can find this under the menu simulate, then once inside go to use custom settings under analysis options.
Kind Regards,
03-31-2013 02:42 AM
thank for your help
