Multisim and Ultiboard
My fuse doesn't blow out
Hello People,
Why doesn't my fuse blow out? What am I forgetting? I simply need something that above I_Limit becomes R=+inf ohm and when I<I_Limit R=0.
Thank you in advance.
Regards.
G
(4,942 Views)
Hello Giancarlo,
I opened and run your short example (thank you for providing that!) and the fuse blows (see attachment).
How long did you simulate? Which MultiSim version are you using?
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,900 Views)
