Multisim and Ultiboard
NEW – Multisim Touch on the iPad
Hi there,
Multisim Touch is currently available for iOS. At this point, other mobile OS platforms are not supported.
Fernando D.
Message 11 of 47
(6,494 Views)
hello Mahmoud_W, on the original multisim, where can i find test vectors such as LD_BAR and CLR_BAR?
Message 12 of 47
(6,353 Views)
I am running the app on my iPad and it seems quite convenient.  I am working with bandpass filters, but need to run the simulation at a higher frequency than 10K.  I have not been able to set the display value high than 10K.  Is this a limit or is there a way to modify this value that I don't see.
Jim
Message 13 of 47
(6,081 Views)
Hi Jim,
You will need to change the maximum frequency of the voltage source. If you open the properties of the voltage source, you can tap on the Frequency variable and then set the Maximum.
Message 14 of 47
(5,730 Views)
I set the max freq to 100k, but I cannot change the display freq to a value > 10k
Message 15 of 47
(5,722 Views)
Is there any way to merge two circuits or to copy and paste part of one circuit to another in Multisim Touch?
Message 16 of 47
(5,157 Views)
This app crashes big time, any solution?.
Message 17 of 47
(4,083 Views)
Hi Raula,
Can you give us more details? Do you have the latest version of the app (version 1.1.2?) What version of iOS are you using? What were you doing before the app crashed?
Jeff
Message 18 of 47
(4,030 Views)
Last version 1.1.2 and iOS 8.4 to 9 always crashes after launching, too much people say the same
Message 19 of 47
(4,010 Views)
I'm very sorry about this problem, can you confirm what iPad device you are using?
Message 20 of 47
(3,982 Views)
