Multisim and Ultiboard
NI Multisim asm file conversion.
we have developed the embedded program in KeilC. through which we can get the A51 file. we like to simulate the same program in NI Multisim circuit design. but it is takimg only asm file. is there any other way to generate the asm file otherwise how we can convert the a51 file into asm file. reply me as soon as possible.
(4,305 Views)
Are you able to generate a hex file?  If yes, place our MCU on the work area you will be forced to go through the MCU wizard, when you select the language, for select the asm option and keep pressing the Next button until the MCU is placed on the schematic.  Now, select the menu MCU>>MCU 8051>>MCU Code Manager. Click on the "New MCU Project" and select "user external Hex file" .
Tien P.
(4,179 Views)
