Multisim and Ultiboard
NILM6 Error Message
Hello, just installed Circuit Design 10.0.1 Student Evaluation Version, and upon startup, I received this error message:
"Due to system clock rollback on your computer, expiring licenses cannot be checked out from this computer. (NILM6)"
Additional Information:
Platform - Windows XP Home Edition (Service Pack 2)
Message 1 of 8
(5,193 Views)
is this the first time you installed it?
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 2 of 8
(5,182 Views)
Yes, this was the first I've ever installed this program.
Message 3 of 8
(5,177 Views)
and you clock is in proper sync? If you push the clock forward and roll it back, it checks the span of the trial time in both directions to see if the limitations are being manupulated.
Message 4 of 8
(5,160 Views)
I'm aware of that "trick" with evaluation software. (Pushing it forward, then rolling it back)  But I never really adjust the clock at all, except for the occassional re-sync with windows.com.  Just to be sure this wasn't the problem though, here's what I did.
Actions Taken:
Uninstalled Circuit Design 10.0.1
Synched clock with windows.com
Reinstalled Circuit Design 10.0.1
I still received the same error message.
Message 5 of 8
(5,145 Views)
I'm betting that is the problem right there, the re-sync. You'll have to contact NI directly to get this resolved, they will not put that info on a public forum to fix this issue.
Send them an email, and they'll most likely get you on your way.
Message 6 of 8
(5,140 Views)
Ok, that's understandable.  Well thank you, but seeing how I will definately need this software, I just purchased it instead.
Thank You.
Message 7 of 8
(5,137 Views)
well I guess that solves your problem and now you have full NI support....:)
I'm not rep or anything, just an user like yourself.
Good luck
Message 8 of 8
(5,134 Views)
