Multisim and Ultiboard
Need some insight on measurements for a single stage amplifer
Hello everyone, I am tasked with having to provide "screenshots of the DC operating point, VCE and Ic,, and oscilloscope readings of Vin and Vout showing the measured peak to peak AC voltages of each along with the frequency of the input signal. " My course unfortunately does not show how to go about this. Attached is an image of my circuit and any instruction on how to achieve these results would be much appreciated. Thank you!
(1,416 Views)
You have posted on the LabVIEW board, I believe you were looking for the Multisim board https://forums.ni.com/t5/Multisim-and-Ultiboard/bd-p/370
Santhosh
Soliton Technologies
(1,406 Views)
I just moved this thread to the proper board.
(1,376 Views)
Thank you for that, my mistake!  Is there anything I need to do on my end to access the proper thread?
(1,349 Views)
Проанализируем этот усилитель в MS
 Видны искажения отрицательной полуволны. Сделаем параметрический анализ, варьируя значением R6.
При R6=30 Ω, искажения исчезают.
Извиняюсь, картинки загрузились наоборот...
(1,325 Views)
