Multisim and Ultiboard
Nested Subcircuits ?
Due to troubles with HB's I think I'll try SC's instead in my next project.  It will be large and probably need nested SC's to get everything on the pages.
Anyone have any problems with this?  Any advice I should have before getting into it?
Thanks.
(3,408 Views)
dbur,
I've discussed this with the team and we think that it is likely that SCs will have similar issues to what you are currently seeing in HBs.   Also the application engineering team has filed a bug report with high severity related to this issue and R&D is currently looking into this, but at this time I have no timeline to share with the community.
In general users using multisection components within HBs (or SCs) should be very cautious and double check the section assignments when exporting the netlist or forward annotating to Ultiboard.
Pat Noonan
(3,372 Views)
I encourage high priority on this issue.  It's going to be a real problem on the project I am working on for the next several months.
Thanks.
(3,357 Views)
