Multisim and Ultiboard
Netlist error message
Hello
i have a problem at Multisim 10
when i press run button an error messages appear
this is the two messages
how i can solve this problem .
(3,965 Views)
Try this:
1.  Go to your control panel-->System-->Advance-->Environmental Variables
2.  Under "user variable for ....", you should see "tmp" and "temp".  Highlight Temp and click on the "Edit" button,
3.  In the "variable value" change the path to point to C:\temp
4.  Repeat step 2,3 for "tmp"
5.  Make sure you have a Temp folder in your C: drive
Tien P.
(3,957 Views)
Thank you very very very much
your solution succeed
(3,952 Views)
