Multisim and Ultiboard
New Component TDA0161
Need help modeling an IC that is not a part of MULTISIM library. Any help is appreciated. The IC is a TDA0161 that was once manufactured by ST.
(3,472 Views)
In this document, you will find a tutorial that explains how to create components in Multisim. You can edit a component with similar characteristics, or get the SPICE model for this device and create it from scratch.
Jose
(3,437 Views)
Do you happen to know where I can find the SPICE model?
(3,433 Views)
You should contact the manufacturer and ask if they have the SPICE model (this is the easiest way), or you can make it by yourself.
Jose
(3,425 Views)
True but it is a discontinued part and I have tried to contact the manufacturer but with no luck.
(3,422 Views)
