Multisim and Ultiboard
New component insert
Hi, I'm from Brazil,
I´m electrical engineering student, I'll graduated this at the end of this year.
I'm doing my "final project" and need to insert one IC TCA 785 in my eletronic drawing but i don't now how to do this, it is possible ?
Marcel
(5,980 Views)
If its in the library, it should be added from within the database manager.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(5,973 Views)
This is the problem, it isn't in the Multisim library
Is it possible to create and insert it with all function described by the manufacturer?
(5,961 Views)
if its not in the database, you can make your own custom components for schmatic and layout, if you want to simulate it, then you will have to find the proper spice model and integrate it.
Sounds like you need to start here:
http://www.ni.com/white-paper/3173/en
(5,959 Views)
I'll try to do Your suggestion.
Marcel
(5,957 Views)
