Multisim and Ultiboard
New to multisim and i need help
I dont know if this is the right forum but where on Multisim can i find a 'LD_BAR' and a 'CLR_BAR'?
(5,781 Views)
Hi Jun_july,
Thanks for getting in contact with your query. I just wanted to get some more information as I'm not completely clear on your question. First off what is it you are looking to do in the software? Secondly, I have not come across an 'LD_BAR' or 'CLR_BAR', could you explain what that is referring to, for example is that a component or something else.
Hopefully we can solve this together.
Best Regards,
Soloman
Application Engineer (CLAD)
(5,740 Views)
HII,
i m using multisim 13.0 version and i dont knw how to add the multiple pages in the same project.......plz anyone knows plz reply....
also how to create netlist report of schematic in m ultisim.......?????
(5,695 Views)
Hi Prajmaneeb,
If you would like multiple pages in the same Multisim project, you can simply create a new design by either going to FILE>>NEW or pressing CTRL+N. It will ask if you want to use a template or a blank design. After you have selected what you want, there will be a new design tab under the schematic diagram.
I've found a tutorial that discusses how to create and modify a netlist file from a Multisim circuit file, please have a look and let me know if this is suitable.
http://www.ni.com/tutorial/5933/en/#toc2
http://www.ni.com/video/646/en/
Best Regards,
Soloman
(5,543 Views)
Thanks for the reponse......
also have problem regarding multisim software .....
i m not able to do netlist in the software .......how to create ....????
(5,530 Views)
Hi Prajmaneeb,
As mentioned in my previous post, I've attached a link to a tutorial which will help explain how to create a netlist file in Multisim. Here are the links.
Best Regards,
Soloman
(5,524 Views)
