Multisim and Ultiboard
Ni multisim schematic
How to open jpg file in ni multisim ???
(5,333 Views)
Hello, thanks for response
as much as I know - there is no direct way to do that but there is a work around -
open blank project
right click -> place grafic      -> picture - -> navigate to your file and make sure the filter is OFF ( all files are supported )
it worked OK for MS11,12,13,14
with hope it helps
good luck
Michael
(5,321 Views)
What do you mean by "open"?
(5,315 Views)
When I right click-place grafic-picture-open it says problem reading in bitmap.
(5,294 Views)
double check please, if your picture file is OK and readable with some other program
with hope it helps
good luck
thanks a lot
Michael
(5,275 Views)
