Multisim and Ultiboard
Non inverting amplifier
                  i have constructed my circuit of non inverting amplifier. How to make some settings,so  that I high frequency gain will be at 25dB and low frequency gain -70dB or less, also the output frequency is  around 9.5KHz. Please correct for me if anything need to be changed with the circuit to achieve these parameters. thanks
(4,759 Views)
I did some changes to your file so that you can best use Multisim in your design and simulation. Please notice the following:
- The opamps are now biased properly using the DC voltage supplies and the on-page connectors named properly
- The AC input should be a small signal from a source component or a signal generator as shown
- Changing the values of some of the resistors and capacitors changes the gain and cutoff frequency of the amplifier which now can be depicted on the bode plotter
- Adding an oscilloscope helps you visualize the input and output signal in the time domain
Hope you find this helpful.
Mahmoud W
(4,750 Views)
thanks mahmoud for your help.
(4,741 Views)
Sir, what changes i have to make on the circuit to acheive this spects:
-low frequency gain=25 db
-cut off fequency= 12.5db
-the high frequency gain less than -70db
-at 35khz  the gain =-20db
-maximum pass band attenuation = 3db
-minimum pass band attenuation =-90db
iam trying to let the cut off fequency at 12.5db but i am not sure which values to set for the capancitor and resistor. any help is appreciated. thanks
(4,712 Views)
sir, the graph does not match with the output response.
(4,708 Views)
It is mainly the values of your capacitors and resistors that will influence the response.
You can refer to "Sedra and Smith: Microelectronic Circuits" for more design fundamentals.
Mahmoud W
(4,705 Views)
sir,
     i still cant achieve  the gain of 17db at cut off frequency 9.5KHz.i have refer to gain equation to change  RC  values but still the 9.5KHz cant match with gain 17db.
(4,683 Views)
