Multisim and Ultiboard
One Shot Monostable Multivibrator
Hi all,
Currently designing a circuit which requires a slight delay after a voltage goes low, and have found that the LTC6993-4 one shot pulse generator, set up as is in the attached file, should work very well for this. Love simulating in Multisim with the live-variable voltages etc, which is exactly how I need to test this device, but I can only find a model of the device in a .asc file (LTspice).
I have read across multiple posts that Multisim doesn't get along with .asc files, but was wondering 2 things; has anyone found a workaround? can anyone offer another component which might fit the bill? I have tried quite extensively with 555 timers, and with RC circuits with a comparator set to trigger after a certain voltage (and hence known time), but neither work quite as I would like (or none that I have trialed).
Looking for a negative pulse (0) of known time after a falling edge of a signal line. 1 otherwise.
No great rush, but would love to see if there is a solution, if not just for my piece of mind. Failing this RS is just down the road, so I can pop over there and buy one of the devices to test out on a board.
Cheers!
Chris
(2,756 Views)
Hello Chris,
I think you can convert LTspice file to net-list and then import it to the Muiltisim.
__________________________________________
The best way to thank, is to give KUDOS
(2,571 Views)
