Multisim and Ultiboard
Operation of Time delay switches
I have a  problem pertaining to the operation of the switches in the ns range. The switch works fine when the on and off time are set in the ms range, but when set in the ns or us range the switch does not respond. Any solution
(5,851 Views)
I believe your question was answer via our Tech Support Dept., however, for everyone looking at this post, this limitation presented by our TD_SW1 ( Time Delay Switch ) is improved and resolved in the next major release (v.10). For any inconvenience, there is a workaround with a circuit schematic that would emulate a TD_SW1 behaviour, however, this might only help if its for simulation purposes.
Nestor
(5,708 Views)
