Multisim and Ultiboard
Oscilloscope doesn't show any result in A/B or B/A trace
Hello! I am trying to get A/B trace of a system. But the oscilloscope doesn't show any result. It only shows time response. I am a beginner at using Multisim and i think i am definitely missing something. I have attached the sim file. Can somebody help me in this regard ?
(2,695 Views)
hello there /
I opened your schematic and did simulation run - it produced DC levels only  - and in that case AB mode should show  you 1 small dot on the screen. and I believe it does it all right.
I am not clear about what your module supposes to do , it looks like sort of analog integrator or something like that.
I 'd recommend to make your module oscillate first , then your  AB mode will be  working properly.
there are a  few extra questions -
what that thing supposes to do ?
are you copying existing design or you creating your own?
with hope it helps
thanks
Michael
(2,647 Views)
