Multisim and Ultiboard
PHASE-LOCKED LOOP
Here is my situation. I need to build a phase-locked loop circuit using the LM565 phase-locked loop component for a simulation for my Lab homework but cannot find any such component in the database. I have tried using the tips and tricks I learned on this discussion board when I last had a similar problem ( I put a * in front of the part number for more options etc). I would try to create my own component except that the instructions in the multisim help are not so straightforward to me. Please help! (I am using "Laboratory Manual (MultiSIM Emphasis) to accompany Electronic Devices and Circuit Theory" by Robert Boylestad).
(8,538 Views)
Device does not exist in my master database of power pro.  So I guess your out of luck unless someone can create it for you.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(8,533 Views)
LM565 was obsoleted about 8 years ago, but there is a PDF on National Semi's website.
There is a Phase Locked Loop under the "Mixed Virtual Components" of Multisim.
A Netlist for a PLL is discussed in this article in EDN -- there is a zip file with the net list:
http://www.edn.com/blog/1700000170/post/1210016921.html
(8,505 Views)
