Multisim and Ultiboard
PIC16F84 C language example
Hi I am new to Multisim , also to Micro controller. i tried to light led many times with Pic16f84 with C language . Can Plz someone  send me the led  example ,or  guide me ?
(10,784 Views)
If you care to look in the samples bundled in Multisim (the blue folder icon next to the "Open" icon), you'll find a few examples with c code in it. Follow these examples to get an understanding of Multisim.
I also found a few tutorials online that you can check out. Try the link below for one of them.
http://www.tentuts.com/2012/01/how-to-use-c-language-in-multisim-for.html
http://www.8052.com/tut8051
Also look into the MCU manuals for an idea of how to use circuit and MCU cosimulation.
http://www.ni.com/pdf/manuals/371752b.pdf
Cheers,
Miguel V
(10,753 Views)
hi
Miguel
Can u plz give me simple example of Multisim C with Pic16f84 like led blinking or powering led which can simulate in multisim 11. it will be helpful to me
(10,725 Views)
Here is a simple program I made that turns on specific ports for the PIC mcu.
#include "pic.h"
#define bitset(var,bitno)    ((var) |= 1 << (bitno))
#define bitclr(var,bitno)    ((var) &= ~(1 << (bitno))
void initialize(void){
    bitclr(STATUS, RP0);    //set bank 0
    PORTA = 0x00;            //initialize
    PORTB = 0x00;
    bitset(STATUS, RP0);    //set bank 1
    TRISA = 0xFF;            //set port a pins to input
    TRISB = 0x00;            //set port b pins to output
void main(){                //main program
    initialize();        //run initialization
    while (1){            //continuous run
        if (RA0 == 0){    //if singal is low then only turn on some port b pins
            PORTB = 0b00111100;
        else{            //otherwise all on
            PORTB = 0xFF;
Just connect a VDD source to the MCU, and to the MCLR pin. Also connect a VDD source to a switch. The other side of the switch should connect to the pin RA0 and VSS (place a 10k resistor between VSS and the switch). Make sure the PIC is also powered (VDD and VSS) and connect and LED to all the RB# pins. With the code above, it should work.
Cheers,
Miguel V
(10,703 Views)
Also check out this tutorial for MCU Co-simulation.
http://www.ni.com/white-paper/5629/en
Miguel V
(10,701 Views)
Hi Miguel V
I tried it in Multisim 12 but it's not working before i makeing post here i got one program from the forum that one also not working .is there any setting problem
 i am attaching my file .
Can youplease go through the file and guide
(10,626 Views)
