Multisim and Ultiboard
PIC16F84A TMR0
I'm not new to multisim but for the PIC microcontroller, I am...for this problem, we were asked to produce an output that can count how many times a button has been pressed, and that we should use the OPTION register, togther with the TMR0 module, we have performed this in the lab and i confirmed that the following code is indeed working in actual...but in Multisim, it cannot be simulated....earlier experiments were succesfully simulated but for this experiment, Multisim just keeps on "freezing", or "not responding", and i end up with no simulation results....
    list      p=16F84A          ; list directive to define processor
    #include <p16F84a.inc>      ; processor specific variable definitions
    __CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
;VARIABLE DEFINITIONS
INT_VAR       UDATA     0x0C
limit	           EQU	.10
RESET_VECTOR      CODE    0x0000  	; processor reset vector
        goto    start           ; go to beginning of program
MAIN_PROGRAM    CODE
start:
; remaining code goes here
movlw	 b'10111000'     ;increment at high to low, counter,1:2 prescaler
OPTION
Banksel	 TRISB
clrf	 TRISB	         ; All pins of PORTB are set to output.
movlw	 b'00010010'
movwf        TRISA
ClearContents
	banksel	PORTB		; Access Bank 0
	clrf		PORTB
	clrf		PORTA
	clrf		TMR0		;Clearing the contents of TMR0
	clrwdt
Push_Button
	movf		TMR0,w
	xorlw		limit
	btfsc		STATUS,Z
	goto		ClearContents
	goto		Display
Display
	movf		TMR0,w
	call		LookUp
	movwf	PORTB
	goto		Push_Button
LookUp
		addwf 	PCL,f 		; PCL is program counter latch
		retlw 		0x02 		; 0 code decimal equivalent
		retlw		0x9E 		        ; 1
		retlw		0x24 		; 2
		retlw 		0x0C 		; 3
		retlw 		0x98 		; 4
		retlw 		0x48 		; 5
		retlw 		0xC0 		; 6
		retlw		0x1E 		        ; 7
		retlw 		0x00 		; 8
		retlw 		0x18		        ; 9
        END             ; directive 'end of program'
 Also, we used the MPLAB IDE version 8.33 in creating this program, and using the .hex file it created to be placed on the PIC16F84A of multisim.I also can't to seem to find a 4MHz crystal oscillator, but there were two 40MHz crystal oscillator, so I assumed the first one to be a typor error.
The attachment below is the schematic diagram we used during this experiment.
(4,253 Views)
Hello Mito,
Is this still a running issue?
If yes, can you then send me the user database your using?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,860 Views)
hello!! i just wanted to ask if u solved ur problem?
i have also multisim and i want to use a PIC16f873 oder PIC16f877 but it doesnt comes in the database
(3,775 Views)
