Multisim and Ultiboard
PID temperature controller
Hallo everybody, I am looking for a PID temperature controller program for Multisim. Please with the 741 op amp. I am also interested in amp circuits. Who can help me! Thanks Bert
(4,235 Views)
Hi Bert,
With a bit of searching I came across the following:
http://www.anale-ing.uem.ro/2009/2009_a9.pdf
It is a nice simple example of a PID controller.
When looking on Figure 1.b you will see the schematic.
This schematic has 5 different parts:
  1. Voltage Follower:  This allows you to uncouple the rest of the circuit from the input, making sure you don't distort the input error signal. (Amplifier with gain 1)
    http://www.electronics-tutorials.ws/opamp/op-amp-building-blocks.html
  2. Proportional: This is the P part of your PID controller. The P factor is the gain of this inverting amplifier.
    http://www.electronics-tutorials.ws/opamp/opamp_8.html
  3. Integrator: This is the I part of your PID controller. The I factor is dependent on both the capacitance and resistance.
    http://www.electronics-tutorials.ws/opamp/opamp_6.html
  4. Differentiation: This is the D part of your PID controller. The P factor is also dependent on both the capacitance and resistance.
    http://www.electronics-tutorials.ws/opamp/opamp_7.html
  5. Addition: This will merge all the correcting signals from the P, I and D component with a certain gain.
    http://www.electronics-tutorials.ws/opamp/opamp_4.html
Please keep in mind that the input is the error signal. To get this signal you need to subtract the desired value from the actual value.
Have a look at the following:
http://www.electronics-tutorials.ws/opamp/opamp_5.html
Lastly I made the following example:
https://www.multisim.com/content/bFq4rZYn2YGh9Yggo2McnA/pid-control/
(You may want to switch around the reference and input temperature depending if you have a positive or negative feedback)
This should be enough to allow you to create your PID controller 🙂
Kind regards,
Natan Biesmans
(4,213 Views)
Thank you Natan. This is a great example.
(4,207 Views)
