Multisim and Ultiboard
PWM Control Circuit
Hello everyone, I was curious if there was a way to implement a counter with a PWM circuit. Ideally I'd like to make a connection with the two in which I hook up a virtual device (like a motor), rotate it so many times, and its "counted" to track its motion.
Below I built a PWM speed control circuit already.
Thanks in advance for any help/guidance!
(2,002 Views)
Здоровья!
Если я вас правильно понял, вы хотите поставить на мотор счётчик оборотов и измеритель частоты вращения вала. Тогда придётся поменять модель мотора.
(1,972 Views)
(1,966 Views)
Hi! Thanks for replying! I think I am more so trying to do something similar to the blocks diagram below.
I do appreciate your help.
(1,942 Views)
Вместо "COUNTER" подставить этот узел
(1,930 Views)
