Multisim and Ultiboard
Partial Discharge
I have some work regarding capacitors charge and discharge, and I need to apply them to multi sim and compare results from mathematical calculations, to calculations from multisim. However im new to Multisim and really unsure how to use it, and which instruments I acquire. Id sincerly appreciate your help if you do not mind.. I have to calculate and show the different results partial discharge multisim , then calculating with different distance
(763 Views)
 It is convenient to study this scheme with shock excitation. At any point in time, you can view voltages at any points on the graphs. As well as currents and frequencies.
(717 Views)
