Multisim and Ultiboard
Phase angle measurement
I'm trying to calculate the phase angles for a simple three-phase balanced circuit. When I use three different AC sources instead of a single three-phase ac source I was unable to measure the phase angles. Please refer to the attachment (Filename:1) and let me where I went wrong.
When implemented using a single three-phase source (Filename: 2), I have tried two ways to view the phase angles
1. Using the voltage and current probes, In this case, the phase angles are measured in reference to the source. Please let me know where I went wrong.
2. Using single frequency AC analysis, In this case, I was able to view the correct phase angles but the phase sequence is wrong. Is there a way to view the phase sequence of the three-phase source?
-Thanks.
Message 1 of 1
(1,180 Views)
