Multisim and Ultiboard
Phase of a transfer function - limited to [-PI,+PI]
How to set the Phase of a transfer function to be continuous? For example, for a 3 pole system, to have a continuous shape between 0 and -270 degrees and to avoid the phase shift, happening when the phase reaches -180, from -180 to +180 degrees. In other words, how to change to the Phase Graph the limits from [-PI,+PI] to a larger range?
(4,853 Views)
Hi Raulo,
The Multisim phase shift graph was set to display +/- 180 degree; unfortunately, there is no way to change this in the graph settings. A request has been made to make the graph display a wider range.
Tien P.
(4,823 Views)
