Multisim and Ultiboard
Pin Aliases
I am trying to put all my circuit on Multisim but I dont want a punch of wires going around. I thought Multisim has the feature of labelling each pin as ALIASES.
Aliases is common uses in the industry for labelling a line or trace and use it in the same page or a different page (same file) with another component. This will help you to clean up everything. Do Multisim has this feature?
(5,232 Views)
You can use the on-page or global connector.  The connectors with the same name mean that the wires are virtually connected to each other.  Connect the connector to a pin; double click on it to change the connector name.
The on-page and global connector are located in the Place>>Connectors menu.
Tien P.
(5,215 Views)
