Multisim and Ultiboard
Pin numbers are moved out of place after upgrade to v12, so are several items checked in Multisim library
I spent a lot of time in the user library V11 making all the number placements look correct to eliminate confusion and make professional looking schematics. Now that I've converted the data base to V12, the pin numbers on components are now out of place. Also, several components checked in the master library have the same problem. Is there a simple solution for this?
(3,094 Views)
Try adjusting your font under Options>>Sheet Properties>>Font.  If this doesn't help, please contact us at: http://www.ni.com/support/ and send an example file plus your user database.
Tien P.
(3,083 Views)
