Multisim and Ultiboard
Port pSPICE model into Multisim
I'm new to multisim.
Can someone provide some basic steps for how to take a pSPICE model (like the one listed at the bottom) and port it into a component in Multisim?
Are there are any general things to be careful with when taking a pSPICE model and using it in Multisim? I would greatly appreciate the tips.
Thanks.
*Jan 2, 2006
*Doc. ID: 75087, S-52635, Rev. B
*File Name: SUPB65P06-20_PS.txt and SUPB65P06-20_PS.lib0
.SUBCKT SUP_SUB65P06-20 D G S
M1  3 G S S PMOS W=5409540u L=0.50u
M2  S G S D NMOS W=5409540u L=0.85u
R1  D 3     RTEMP 9E-3
CGS G S     3100E-12
DBD D S     DBD
.MODEL  PMOS        PMOS ( LEVEL  = 3           TOX    = 7E-8
+ RS     = 6E-3            RD     = 0           NSUB   = 9.5E16
+ KP     = 8E-6            UO     = 400
+ VMAX   = 0               XJ     = 5E-7        KAPPA  = 5E-2
+ ETA    = 1E-4            TPG    = -1
+ IS     = 0               LD     = 0
+ CGSO   = 0               CGDO   = 0           CGBO   = 0
+ NFS    = 0.8E12          DELTA  = 0.1)
.MODEL  NMOS        NMOS ( LEVEL  = 3           TOX    = 7E-8
+NSUB    = 1.5E16          NFS    = 1E12        TPG    = -1)
.MODEL DBD D (CJO=2500E-12 VJ=0.38 M=0.37
+RS=0.1 FC=0.5 IS=1E-12 TT=6E-8 N=1 BV=60.2)
.MODEL RTEMP RES (TC1=11E-3 TC2=5.5E-6)
.ENDS
Fred
*Kudos are appreciated.*
(9,465 Views)
Multisim has the ability to simulate a wide range of SPICE-based models.  Over the past few releases, great efforts have been focused on assuring compatibility of the parser with simulator-specific parameters so that your circuits can be seamlessly ported over to Multisim.
To simulate this particular model in Multisim, you will need to create a custom component in Multisim.  The following tutorial will guide you through the process: Creating a Custom Component in NI Multisim.
Alternatively, you can use the Arbitrary SPICE Block component to paste in your netlists for quick tests.
Let us know if you have any more questions along the way.
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(9,451 Views)
