11-02-2011 08:16 AM
Hi
I am a first year Electronic engineering student and I would for obvious reasons like to get to know and use Multisim.
So i decided to build a power supply on it to test with different loads and gadgets attached to it.At first it looked quite easy until
I realized that there's some components that I cant find on the database and would have to make myself.Im not that PRO yet and I only have 6 days left on the trial.
Could someone please help me out? Just point out the Equivalent Components on the NI database
Here is the Power Supply I want to build and simulate on Multsim.
http://www.rason.org/Projects/powsupply/powsupply.htm
I had trouble finding a Voltage Regulator and Some of the Transistors aswell.
Thanks and Regards
Cart
Solved! Go to Solution.
11-04-2011 09:18 AM
No One?
How Unfrotunate. 😞
11-14-2011 11:05 AM
If you cannot find a component in Multisim you can always create it using the Component Wizard (Tools menu), here is a basic tutorial:
In order to create a simulatable component you need a SPICE model. SPICE models are created by the manufacturers therefore, visit the manufacturer's website to see if they have the model you need, you can also use a search engine.
For your reference I am attaching a Multisim file with the LM723. You can save it to yourUser Database, just right-click the component and select Save Component to DB.
I hope this helps, welcome to Multism!
