Multisim and Ultiboard
Power source
Hello everyone,I made a circuit on Multisim and for the power I used Vcc = 5 V and ground.When I replace the power source with a 5 V battery and replace Vcc with the + terminal and replace ground with - terminal,my circuit won't work why? What is the difference between Vcc and a DC power source?
(2,953 Views)
Hi!
You replace it with the + and - terminal of what? Can you give us a screenshot?
(2,912 Views)
Hello, sorry for late reply -  I solved the problem, we need to specify ground in simulation as there may be negative voltages as well in the circuit .
(2,876 Views)
