Multisim and Ultiboard
Problem when using the Agilent Function Generator and the AD633 multiplier circuit.
I have a problem when using the Agilent Function Generator and the AD633 multiplier Circuit in that I get the following simulation error: "A simulation error has occurred. Would you like to run the Convergence Assistant to attempt to resolve this problem automatically?". This error is absent when I use the standard function generator or any of the "Signal Voltage Sources" like the AC_VOLTAGE. I am stuck Smiley Sad.
I am using Multisim 14.1 Student edition. The Circuit is attached.
Lars
Message 1 of 1
(2,707 Views)
