Multisim and Ultiboard
Problem with Oscillator dont run
May someone help me?This simple oscillator doesn´t oscillate. At real breadboard its ok. See attached. Thanks.
(4,458 Views)
I tried your circuit and it didn't oscillate.  So, as you're dealing with a charge and discharge of a capacitor in your circuit, I changed your simulation settings to "set to zero."  It still didn't oscillate with the large electrolytic.  So I changed the value to 0.1uF and tried it.  After closing the switch and charging the cap to about 0.9 volts, I then opened the switch and it began to oscillate.
Leaving it to run while I responded to you, I see that I have returned to a, roughly, 40mvp-p triangle at about 2ms repetition rate.
So, give the above a shot and see what happens.
(4,455 Views)
Dear Euler,
The expected is the circuit oscillate when the power is on. In this case it doesn´t oscillate. Thank you but yet stay the problem.
Would you or anybody may help me?
Mpamponet
(4,437 Views)
Why should the circuit oscillate?  What about its design causes it to oscillate?   If the circuit is supposed to oscillate upon power-up, why include a switch?
(4,434 Views)
In fact I´d like to understand how this circuit oscillate because in practice it oscillates. The swtich doesn´t matter. It was a try to start the oscillation.
mpamponet
(4,417 Views)
Here have two links to help to help you.
http://zone.ni.com/devzone/cda/tut/p/id/5662
http://www.angelfire.com/electronic/beausalector/transistorastblcircuit.html
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(4,402 Views)
