Multisim and Ultiboard
Problem with PCB layout
Hi all,
I have made some components footprint and I tried to use them.  Some footprints are working fine, but some have problems.  When I transfered to Ultiboard, I got this error.  The components are connected on both pins.  Picture is attached.
thanks,
Harrison
(3,235 Views)
You should return in Multisim and to check up bad components. For this purpose it is necessary to make double click by a mouse on a component and to choose Edit footprint. In the opened window to check up conformity Simbol Pins and Footprint Pins. After editing of all components to choose Transfer>> Forward annotate to Ultiboard.
(3,227 Views)
