Multisim and Ultiboard
Problemms with simple XSpice model
I try to create a simple XSpice model. For example NOT-element.
I wrote MOD and IFS files and compiled it. But element work one time, when i start simulation.
IFS-file
NAME_TABLE:
C_Function_Name: cm_testor
Spice_Model_Name: testor
Description: "A simple gain block"
PORT_TABLE:
Port_Name: in out
Description: "input" "output"
Direction: in out
Default_Type: d d
Allowed_Types: [d] [d]
Vector: no no
Vector_Bounds: - -
Null_Allowed: no no
Mod File
SPICEdev * FAR DynDEVices[] = {
    &cm_testor_info
#include
#include
void cm_testor(ARGS)
	if(INPUT_STATE(in) == ONE)
		OUTPUT_STATE(out) =  ZERO;
	else
		OUTPUT_STATE(out) = ONE;
(4,528 Views)
Hi Werewolf-Prank,
Can you send us the source code, the compiled dll and circuit you used to test the model.
Tien P.
(4,497 Views)
Code and project in the attachment
Thank you
(4,482 Views)
Any body can help me?
(4,421 Views)
Accepted by topic author Werewolf-Prankster
I am sorry for the long delay, I was only able to get you code to work during the intial stage but when the simulation was running the component didn't toggle between high and low.  I had to get help from a developer to make this model  toggle between high and low during the simulation.
Attached is the .mod, ifs and the dll we created.   In the .mod file, we modify your code to include a delay, without the delay Multisim will not toogle during simulation.  Also, in the .ifs file, I added a parameter section  for the rise_delay paremter.
When you create a component in Multisim using the Component Wizard, in step 1, make sure you select "Digital" under "Component Type" and then select "Til" from the "Component Technology" field.
Tien P.
(4,359 Views)
