01-21-2013 01:36 PM
Does NI have a recommendation for an efficient Product Data Management system that is compatible with multisim and ultiboard files?
Solved! Go to Solution.
01-22-2013 08:56 AM
Can you provide us some details about what you are trying to accomplish.
01-22-2013 09:59 AM
We need to vault our schematic and layout files for archival purposes, and for maintaining issue control.
01-22-2013 10:06 AM
and also for data sharring, fab and assembly data.
01-22-2013 10:31 AM
I'm not sure about a third party tool but you can accomplish this using Projects in Multisim. Go to File >> Project and Packing >> New Project. You can add all the required files related to a single project and then save everything together. You can also setup version control and keep track of all the changes. This is a really easy way to archive your files as it saves everything in a compressed zip folder with a special extension understood by Multisim.
Hope this helps.
01-22-2013 10:48 AM
Thank You. We'll try it out.
