Multisim and Ultiboard
Pulse Position Modulator and Demodulator
Hello, I'm trying to recreate these results...
for this circuit
Here is my, circuit in multisim
But the signal formed in the oscilloscope is nowhere near the desired results. What am I doing wrong here?
(2,981 Views)
Hi StudentGoh,
I have some questions that need to be clearly understood for me.
1. Did you create this project by yourself, or you took it from Multisim examples?
2. Can you share "faction generator -XFG1 and XFG2" paraments with us for replication?
Also, I checked, there is a different voltage compare with this part of circuit through which you created yours. From the right picture you can see that the opamp varies around -15 to 15 volts, but there is not any negative voltage in there.
Regards)
(2,624 Views)
Вот простой вариант, выдающий нужные вам результаты. Частота, амплитуда, фаза, смещение устанавливайте по своему желанию
(2,610 Views)
заработал 0,5 модулятора
для быстроты симуляции частоты увеличены
(2,575 Views)
-попробовал идти дальше, получил такую картинку из Вашей симуляции
(2,556 Views)
