Multisim and Ultiboard
Putting text in the soldermask
Is there a way to put text in the solder mask layer?
When I try to do so (select solder mask top or bottom/place/graphic/text), the text button is grayed out.
I'm using Ultiboard V10.01
I'd like not to add an extra silkscreen, for the few letters that nee to be placed in a new layout....
this way, the board will be a little cheaper...
Stressed user
(3,217 Views)
For putting text in the Soldermask Layer use DXF import
(3,211 Views)
