Multisim and Ultiboard
RTD simulation Help
I am trying to use a VOLTAGE_CONTROLED_RESISTOR_VIRTUAL to simulate an RTD. From what I have read this is one way to simulate an RTD. I am using the voltage input as a simulation for temperature.
I want the value of my resistor to be 279.40 ohms @ 103.12 degreec C (or volts in this case).
I set the voltage supply to my VCR to 103.12V and the resistance value to 2.70946 ohms/volt
Am I missing something? What am I doing wrong?
Thank you,
Eric
(6,076 Views)
Hi Eric,
I duplicated your circuit and there are two things you need to do get the right measurement:
- Reverse the polarity of the biasing battery, so the positive of the 103.12 battery to the positive of the voltage controlled resistor (VCR) and same for the negative end.
- When measuring the resistance of a VCR, it is better to measure the voltage accross and divide it by the current passing by because of the way the Ohmmeter device works (it adds a sample resistor in shunt and that will be affected by the controling voltage too). Another way is to run a DC operating point analysis and calculate this expression (V(1)-V(2))/I(R1).
I attached the design here.
Please let me know if you have other questions.
Mahmoud W
(5,974 Views)
Greetings I am trying to simulate a 2 lead wire RTD using a VCR however i have issues with finding how to show how the resistance of the VCR changes with control voltage. My maximum control voltage is 105v which represents the temperature. Please help
(2,882 Views)
