Multisim and Ultiboard
Re: Placing a Negation Bar (overline,overbar) for global connector nets and text
Hi
I need a help about How to place overline for net names to indicate active low signal?
(3,309 Views)
I hope this is helpful and that the Multisim protocol has not changed too much since multisim 2001.  Previously, the Pin input wedge and Pin output wedge, were used to indicate Negative Active Input Signals and Negative Active Output Signals.
Please find enclosed attachment from Multisim 2001 Commercial User Guide: Pins.pdf
(3,281 Views)
Hi biscom
         Thanks for the reply.
         But i need a solution to use active low signal using overline in net name.
         Is there no option in multisim?
(3,273 Views)
