Multisim and Ultiboard
Reactive power meter in Multisim
Hello, is there a way to create a three phase reactive power meter using the components/instruments provided in Multisim v12?
Thanks in advance!
Multisim 12.0.0
(9,742 Views)
Hi Tobster
Una solucion que se me ocurre es que utilices 2 wattmeter en conexion Aron y asi puedes calcular la potencia reactiva del sistema trifasico.
Saludos
Alvaro Tasco
(9,740 Views)
Thank you for the quick reply!
Conexion Aron is the same with 2 wattmeter method? I attached a screenshot with the connections and the formula for reactive power. If they are correct, please confirm.
Multisim 12.0.0
(9,730 Views)
Accepted by topic author Tobster
Hi Tobster
1) Yes.. Conexion Aron is the same  with 2 wattmeter method.
2) The connection is fine. But the formula is Q = sqrt (3) (XWM2-XWM3)
  (XWM2+XWM3) =P
  Sqrt (3) (XWM2-XWM3) = Q
  S = P + JQ
Att:
Alvaro Tasco
(9,718 Views)
Thank you for your time!
Multisim 12.0.0
(9,710 Views)
how about single phase reactive power meter
(4,545 Views)
