Multisim and Ultiboard
Reading Error
Hi, I have encountered a problem with my Multisim circuit. I have thrown in a spdt switch to vary between 2 voltages which are; 5 v and 3.3 v respectively but the problem is that when i toggle the switch to the 3.3 v terminal, I'm getting a voltage on the other terminal and i cant understand why. Can someone help me rectify this please?This is where im supposed to get 3.3v but im getting 4.5 on the other terminal of the switch alsoThis is where im supposed to get 3.3v but im getting 4.5 on the other terminal of the switch alsothis is where im suppose to get only the 5vthis is where im suppose to get only the 5v
(2,434 Views)
Hi Antoines,
With the first switch position, you are actually reading an open with the multimeter (you are not actually reading a signal) since you are measuring a from an open terminal to ground. The multimeter can measure anything since it is an open terminal, y real life you can be measuring noise at that moment. I wouldn't take into account that value.
Regards
Hector M
(2,348 Views)
