Multisim and Ultiboard
Real time signal acquisition using NI ELVIS II+ and and modifying in Multisim and giving giving back to NI ELVIS II+ to give the output to external world
   I need help in doing the following in Your software.
I am describing my requirements in steps
1. Get a signal form sensor to LABView using DAQ
2. Pass this signal to multisim where the signal from sensors has to be amplified and any modifications required which i want to do.
3. after performing the required operations i need to give this signal to labview.
4. Using DAQ again i have to give this modified output to external world.
How i can do all these things mentioned here can any one help me to figure out this.
An image is attached which shows what i require
(4,620 Views)
Hi..
 I just want want to tell you that you can use LVM(labview measurement file), through which you can write the aquired real time data and then you can use the data in multisim. Or else go for Multisim LabVIEW Cosimulation. But these things may not satisfy your need completely since it consumes time for processing rather than aquiring time.
(4,592 Views)
