Multisim and Ultiboard
(Reference#7231113) Under this reference, I'd like some help from NI Multisim.
While the simulation was running I saved the data three times, under three unique filenames.  I'd like to retrieve as much of the simulation data (that I'd set up) as I can so that I can send the data to Excel.  What advice do you have regarding how best to do that?
Of course I'll send you the files if it is necessary, both to retrieve the data and to help you figure out what went wrong; although, I'm thinking that you may already have the data.
(3,490 Views)
Hi Eulers,
If you want to export the simulation data to Excel, select View>>Grapher and then select Tools>>Export to Excell.
Tien P.
(3,451 Views)
So are you saying that I can load one of the saved files (I saved under new names several times while the simulation was running,) not run it, but then look at the grapher of the old run instead?  I'm trying to get old saved data, not new data.
(3,447 Views)
