Multisim and Ultiboard
Reference ground - transientanalyse
I'm making a transientanalyse, my cuircuit has a DGND and a AGND. To which of those grounds does the analyse refer???
Thx
(5,304 Views)
There is no component called AGND. I am assuming you are referring to the "GROUND" component. Any net connected to this component is net 0, which is the reference net for simulation.
DGND can be used to create an alternate ground in the schematic capture environment. However, in simulation, DGND is shorted to net 0 so DGND and GROUND are the same.
Max
(5,292 Views)
OStep escreveu:
Just as OStep said, DGND and GROUND are the same. But, if you go on the Select Component window, you will see the difference between them.
DGROUND is digital ground and
GROUND is analog ground.
I think you could conclude what type of ground is designed for depending on the nature of the circuit.
Hope it helps!
(5,282 Views)
@leo.ni wrote:
OStep escreveu:
Hope it helps!
Thanks guys for your replies.
Indeed there is no AGND, GROUND was meant. The shortening of the DGND and GROUND explains my simulation results.
(5,269 Views)
