Multisim and Ultiboard
Relay properties
Can I input relay properties in the virtual relay library?  I am trying to use a 12v relay, with a know coil resistance.
(3,584 Views)
In Multisim there are many different relay models, look in the "Basic" Group under the "Relay" and "Basic Virtual" family.  Also, look in the "Electro Mechanical" Group, there are various relays in there as well.  Relay in Multisim are behaviour model, when the voltage/Current reaches a certain level, the relay switches.  If you place the relay on the work area, double click on it and you'll see what option is available to you.
Tien P.
(3,558 Views)
